Diff ratios
  • gray
07 Jan 2012 13:40 #30211 by gray
Diff ratios was created by gray
Can anyone help?
Does anyone know what the diff ratio options are on Jimny.
Have a feeling this jimny has had a diff replacement but may not be the correct one.
I can count how many pinion turns = 1 wheel turn to work it out.
I would just like to know if there are alot of diff options out there, so ensure get a correct diff to replace it.
07 Jan 2012 13:53 #30212 by facade
Replied by facade on topic Re: Diff ratios
Alongside the BigJimny.com flash there is a menu in red
Click on "information" then "general information" then "Transfer box and Diff ratio information"
  • mcjimny
07 Jan 2012 18:33 #30218 by mcjimny
Replied by mcjimny on topic Re: Diff ratios
As i understand it the only difference in ratio is on the automatics vs manuals. If its a different ratio then it could easily be from an auto.
There was a thread recently discussing the differences in the diffs in terms of number of bolts and spline count. I think the vvt ones have more bolts and different spline count.
heres the link : www.bigjimny.com/index.php?option=com_ku...8235&Itemid=75#28237
  • panosd
09 Jan 2012 07:15 #30331 by panosd
Replied by panosd on topic Re: Diff ratios
Hello ,
jimnys until 2005 have 11/43 diff ratio. ( 3.909 )
jimnys from 2006 and after have 10/43 (4.300)
and there are also the diffs from the japan spec jimnys 2001 sport with 11/45 (4.091)
These are the stock availiable.
If you want something aftermarket the only option here is the r&p from here
5.1:1 --> www.californiaclub4x4.com/jimny/423--jimny-51-1-4xfourart.html
Time to create page: 0.153 seconds
