fitting wagon engine into jimny
08 Jan 2012 09:54 - 08 Jan 2012 09:57 #30241 by facade
Have a search around goggle etc.
Fairly sure someone has done it, by changing the sump and oil pickup, and the cam shaft, I think the engine speed sensors are different.
I expect the block is near enough the same, so if you have the original engine to rob parts off it should be ok, but there are plenty of rolled jimnys about to get an engine that does fit straight in.
EDIT the engine needs to be the same type eg single cam or twin cam as the electronics are too different.
The gearboxes and therefore engine backplates are different, but they might change over.
Last edit: 08 Jan 2012 09:57 by facade.
  • louelli17
10 Jan 2012 15:37 #30487 by louelli17
Replied by louelli17 on topic Re: fitting wagon engine into jimny
a suzuki wagon r engine its the make of the car thanks
Time to create page: 0.076 seconds
