Quick question
  • novacav
03 Jan 2012 22:42 #29925 by novacav
Quick question was created by novacav
Hi there today I picked up my jimny very impressed so far for the next few months it's going to be my only car so will be used for pay and play days at bures a bit of greenlaning and general getting about
Question is there any way to turn the airbags off as don't fancy them going off when offroad
It's a 2000 w reg hard top
Thanks Michael
  • p1ngu32
03 Jan 2012 22:55 #29928 by p1ngu32
Replied by p1ngu32 on topic Re: Quick question
There is a sequence for disconnecting them in the workshop manual, but it will leave your airbag light on which will likely cause problems at MOT time. I think most people just leave them connected there arent any reported issues of them going off while offroading, they arent sensitive enough. If you are having a serious enough incident off road for them to go off it is likely you would be glad you still had them connected :)
  • 247sniper
03 Jan 2012 22:55 - 03 Jan 2012 22:57 #29929 by 247sniper
Replied by 247sniper on topic Re: Quick question
Hi mate, you have to be going over 8 mph and in a collision for the air bags to deploy, it may even be more!
Or if you really want you can pull the SRS fuse, that will disarm the airbag system competly, but it's not as simple as putting the fuse back in and all will be ok . The SRS systems will store a fault and the air bag light will remain on, and no air bags will work in the event of a RTA.
Hope this helps
Steve.
Last edit: 03 Jan 2012 22:57 by 247sniper.
  • blakey2000
04 Jan 2012 02:37 - 04 Jan 2012 02:38 #29934 by blakey2000
Replied by blakey2000 on topic Re: Quick question
From my knowledge, most airbags require at least a deceleration force of around a 23km/h (14mp/h) frontal collision but this speed and force required, is different in all vehicles as not all vehicles are designed the same.
But as p1ngu32 said if your hitting something with enough force to cause the airbags to go off, then your gonna want them there whether your offroading or not. but even if you disconnect them, reconnecting them can set them off. it only takes a few amps as low as 1-2A to set them off, easily achievable through a dirty pin. and if you set them off, your going to have to get new ones and they aren't cheap. best to leave them in my opinion.
Last edit: 04 Jan 2012 02:38 by blakey2000. Reason: not every one uses km/h
04 Jan 2012 06:48 #29940 by mlines
Replied by mlines on topic Re: Quick question
My Jimny has been heavily off-roaded from new (take a look at the damage currently on display on the front page of the website) and has not had any issues with the twin air-bags that are fitted.
  • darthloachie
04 Jan 2012 07:33 #29943 by darthloachie
Replied by darthloachie on topic Re: Quick question
mine neither and i have parked it on its nose occasionally
Time to create page: 0.192 seconds
