Spotlight brackets
  • coptleigh
30 Mar 2010 20:50 #2973 by coptleigh
Spotlight brackets was created by coptleigh
Are there any kind of specific brackets for mounting a couple of spotlights to the front on my Jimny??
Cheers
Alan
  • ooky_123
31 Mar 2010 07:57 #2974 by ooky_123
Replied by ooky_123 on topic Re:Spotlight brackets
Ive seen spots mounted straight through the bumper to a plate sandwiched underneath. Not sure how successful this has been (prone to wabble / vibration) plus you have to drill the bumper.
Im not aware of any standard brackets out there in Jimny Land, you rprobably going to see if there is someone who can fabricate you a pair.
This kind of thing makes me wonder why there are no one cashing in on the jimny modifications market in a big way.
sure ORA offer a custom fabrication facility, but they never seem to return my calls or emails...
KAP also said they could custom Fabricate, but they are in Bradford, 130 miles away. Rino Ray is on the south coast, but Ive not had any dealings with him.
Might be another thing for Martin to considder ... spotlight brackets ...
31 Mar 2010 08:09 #2975 by mlines
Replied by mlines on topic Re:Spotlight brackets
Part of the problem with things like this is that I don't have a standard Jimny to look at to come up with a design.
Then its forecasting how popular an item will be. I guess KAP/ORA are aiming at the high value, low volume items.
We have plans for a few items (such as a replacement "floor" for the boot to make a level load space) but the introduction of each one takes time. We just have the Panhard rods coming through and this started in January.
If someone could show how a spotlight bracket would fit a standard Jimny then we can make them
  • ooky_123
31 Mar 2010 08:18 - 31 Mar 2010 08:20 #2976 by ooky_123
Ive just been out to look at the Jimny. I suppose the best place to locate such brackets would be the front cross member, and run them up and out below the bonnet. Only problem I could see was the length of the bracket may cause Wobble, and if you go too thick on the bracket, you could take the paint off the bonnet lower lip.
Another option would be to mount to the same mount points used to bold the bumper on.... let me go and measure clearances
Last edit: 31 Mar 2010 08:20 by ooky_123.
  • coptleigh
31 Mar 2010 13:20 #2978 by coptleigh
Replied by coptleigh on topic Re:Spotlight brackets
Thanks for the replies dents, look forward to more info, in the meantime, I'll get my thinking cap on and see what I can come up with.
Cheers
Alan
31 Mar 2010 14:46 #2979 by maverick
Replied by maverick on topic Re:Spotlight brackets
just stick them on with Sikaflex .. that keeps my mud-guards on!!
Of course, I was only joking - but i do recall seeing a Jimny with a mod on the bonnet - aka Rally-stlye!!
Jalapeño, IISY?
Time to create page: 0.743 seconds
