screaching on startup
  • grumpy22
14 years 10 months ago #29370 by grumpy22
screaching on startup was created by grumpy22
Alternator or drivebelt?
Lasts about 30 - 40 seconds varies with revs and electrical load, stops when sprayed with wd40, could be either but ones a cheap fix the other isn't
cheers
14 years 10 months ago #29372 by maverick
Replied by maverick on topic Re: screaching on startup
Same as mine - I'm reliably told its my FAN Belt and not to worry... other than it might be too tight.
I need to adjust (slacken off) it to prove this - but at the moment -- CBA.
Jalapeño, IISY?
  • 247sniper
14 years 10 months ago #29375 by 247sniper
Replied by 247sniper on topic Re: screaching on startup
It is most likely you alternator belt if it is changing with electrical load added and taken off. Basically when you put the rear heated screen, heater, lights etc on there is a greater demand for power, more load on the alternator = squeals more when revd. If it has been noisy like you said I'd recommend replacing the belt as its probably knackered now anyway, they aren't expensive. All you are doing when adding WD40 is lubricating the belt and pulley temperelly reducing the noise, although its still slipping.
Get it changed, their not costly to get fitted either.
Steve.
  • grumpy22
14 years 10 months ago #29380 by grumpy22
Replied by grumpy22 on topic Re: screaching on startup
Ahhh but!,,
Perhaps the wd40 is getting to the bearing that's causing the squeal
Chicken and egg
  • 247sniper
14 years 10 months ago #29382 by 247sniper
In 15 years in the motor trade I have never heared a alternator bearing squeal....... grind, rumble and bang yes but not squeal. If it was a bearing then it would get worse due to heat and expansion, not disappear.
WHat you have described is a belt noise, but do check all the running and idler pulleys are free when the belt is off to insure none f the have not seized.
Steve.
  • little jimny
14 years 10 months ago #29386 by little jimny
Replied by little jimny on topic Re: screaching on startup
Mine squealled like a stuck pig for about a month before the alternator finally went berserk and threw 19V at the battery. It was at its worst after starting the car and moving off. I thought it must be the belt, but it was fine. One replacement alternator later and all was well in my Jimnys world
Time to create page: 0.099 seconds
