Split Charge System.
- wanderinstar
22 Dec 2011 20:51 #28991
by wanderinstar
Split Charge System. was created by wanderinstar
I intend fitting a secondary battery on the n/side inner wing,after moving the washer bottle forward. Question is how do I fit a split charge system.Been on the bay and there is one for about £.20 while others are about £70-80. Reading the bumf it appears that the secondary battery takes its power from the vehicle battery while the ignition is switched on. Have I got this right?
Ian.
Ian.
- reaper
22 Dec 2011 20:55 #28993
by reaper
Replied by reaper on topic Re: Split Charge System.
the one i had on my camper was £5 from towsure
your alternator charges your main battery and when thats full it flicks over and charges the slave
on a normal car battery it doesnt need much charge so most of the time its charging the slave
- wanderinstar
22 Dec 2011 21:03 #28996
by wanderinstar
Replied by wanderinstar on topic Re: Split Charge System.
I presume that was just for the relay? How did you wire it up?
- r_ogilvy
22 Dec 2011 21:03 #28997
by r_ogilvy
Replied by r_ogilvy on topic Re: Split Charge System.
i have a t max system with a push button in the cab, its normally on manual but theres a button for auto, and i dont even know how it works it was there before i had it, i guess if i press auto it will do the one with the least charge??? its normally on the manual button when you switch the ignition on. i dont no :huh: !!
- reaper
22 Dec 2011 21:08 #28999
by reaper
thats basicly what a split charger is , a relay
power in (from alternator)
output 1 (to car battery)
output 2 (to slave battery)
simples
wanderinstar wrote: I presume that was just for the relay? How did you wire it up?
simples
- r_ogilvy
22 Dec 2011 21:14 #29002
by r_ogilvy
i have this, which button does what :huh:
Attachment t-max-split-charge-system-2809-p_2011-12-22.jpg not found
Time to create page: 0.176 seconds
