Kingpin bearings
  • wanderinstar
14 years 10 months ago - 14 years 10 months ago #28931 by wanderinstar
Kingpin bearings was created by wanderinstar
G.tting the jobs done now we have a bit of decent weather.(at last)
Done the kingpin on nearside today. All went to plan but I had a slight problem. When taking off the circlip I found that one of the holes,(for circlip pliers to go in) was about half the size of the other one. Caused a problem, but not unsurmountable.
Has anyone else had this problem?
You could certainly tell which bearing was the bottom one. How does water get in there in the first place, because judging by the underside of the car I an 90% sure it hasn't been of .froaded.
Ian.
Last edit: 14 years 10 months ago by wanderinstar.
  • mcjimny
14 years 10 months ago #28972 by mcjimny
Replied by mcjimny on topic Re: Kingpin bearings
The circlip holes are that way i presume so that one side is a tight fit for the pliers to work against.
The water will get in around the swivel seals especially if they're getting old. Even if its not been offroad they wear as any water sits in the bottom bearing. I had a year without taking mine off road but it still hammered the bearings.
  • wanderinstar
14 years 10 months ago #29031 by wanderinstar
Replied by wanderinstar on topic Re: Kingpin bearings
I couldn't get the pliers in. It is either a crafty ploy by those little people who build Jimny's to try and get you to use main dealers or a faulty circlip. Due to lack of response on here I suspect the latter.
Ian.
  • mcjimny
14 years 10 months ago #29032 by mcjimny
I can only just get mine in and have to kind of push and jiggle it! :lol:
14 years 10 months ago #29109 by facade
Replied by facade on topic Re: Kingpin bearings
wanderinstar wrote: I couldn't get the pliers in. It is either a crafty ploy by those little people who build Jimny's to try and get you to use main dealers or a faulty circlip. Due to lack of response on here I suspect the latter.
Ian.
No they are all like that. Very difficult to undo. I guess we are so used to doing the impossible that 10 minutes fiddling with a circlip doesn't get a mention ;)
Time to create page: 0.082 seconds
