spacers
  • shootinginger@yahoo.co.uk
21 Dec 2011 17:41 #28841 by shootinginger@yahoo.co.uk
spacers was created by shootinginger@yahoo.co.uk
fitting my spacers tomorrow, do i need longer brake hoses? and whats the easiest way to go about fitting them?
  • mcjimny
21 Dec 2011 18:00 #28848 by mcjimny
Replied by mcjimny on topic Re: spacers
As in spring spacers?
Its simple, support one side and put the jack under the other. Undo the shock mount and let the jack down slowly as your brakeline will be maxed out. The spring should drop out or at least be near to it.
Remove the old rubbers at the top and give the seat a good clean, put the new one in place and put the spring back in. Jack it up so its just supported and make sure the spring is in the correct position. Jack right up(you may need a block to get a bit extra height) and replace the shock bolt - the hardest part if you're not fitting the shock spacers. I had to fight like hell to get mine to extend by hand enough to get the bolt in.
Before doing anything, spray all the bolts with the famous penetrating fluid! I did mine for a few days before.
I've not got extended lines yet as i've still got my ARB in place so that limits front articulation.
