Rad Fan, when should it spin
  • Jimny_2000
27 Mar 2010 09:15 #2875 by Jimny_2000
Rad Fan, when should it spin was created by Jimny_2000
Im not sure if something is wrong. But when l start up my X Reg (2000 model) and the engine is cold l notice my raditor fan is spining straight away.
Is this normal? Or should it only spin/turn when it reaches a set temp (hot)?
Thanks in advance.
  • Garry
27 Mar 2010 09:39 #2876 by Garry
Replied by Garry on topic Re:Rad Fan, when should it spin
the fan is on fulltime, its run of a belt on the bottom pully.
  • Jimny_2000
27 Mar 2010 10:04 #2877 by Jimny_2000
Replied by Jimny_2000 on topic Re:Rad Fan, when should it spin
Thanks for the quick reply.
I did notice it was on the pully but thought it may of had a method of cutting in and out.
  • Garry
27 Mar 2010 11:19 #2879 by Garry
you can fit an eletric fan, im going to be doing this soon, the local site i play on has alot of water crossings, so id like to be able to switch the fan off when going through
Time to create page: 0.143 seconds
