Jimny veering wildly when in four wheel drive
  • DavidMitchell
29 Dec 2011 10:38 #29421 by DavidMitchell
Replied by DavidMitchell on topic Re: Jimny veering wildly when in four wheel drive
almost on the verge of giving up! Won't go into 4 wheel drive at all now!
29 Dec 2011 15:04 #29435 by facade
What has changed since the last time it went into 4wd?
Just the rear diff?
Or have you messed with the transfer box?
Try rocking the car slightly backwards and forwards.
  • DavidMitchell
05 Jan 2012 11:48 - 05 Jan 2012 11:52 #30047 by DavidMitchell
we can manually (at the front hubs) engage 4wd and it drives quite happily. But - we are able to select 4wd using the lever but we get a flashing 4wd light and 4wd does not engage
Last edit: 05 Jan 2012 11:52 by DavidMitchell.
  • DavidMitchell
05 Jan 2012 11:58 #30050 by DavidMitchell
have swapped some vacuum hoses on the osf and we can now engage and disengage 4wd from within the vehicle!!!!!!!! but! - we still have the flashing 4wd light :(
  • goatboy
05 Jan 2012 12:32 #30053 by goatboy
have you seen this article?
www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Trouble shooting towards the bottom...
  • DavidMitchell
06 Jan 2012 11:00 #30137 by DavidMitchell
I have a PDF document which contains a diagram of the 4wd controller. unfortunatley it is for a newer jimny! I am working throught the "checking the vacuum hubs.pdf" and am trying to do number 22 (checking voltages across the connector) but can't identify which connector it is. the VIN number of the jimny ends 00137918 if that helps
Time to create page: 0.192 seconds
