Jimny veering wildly when in four wheel drive
- DavidMitchell
16 Dec 2011 11:21 #28337
by DavidMitchell
Jimny veering wildly when in four wheel drive was created by DavidMitchell
First post and hoping you guys can help
J Reg Jimny required it's front axle replaced (spheres were heavily corroded) for it's MOT so bought one from a scrapyard. Axle arrived, with ABS (no ABS on vehicle). Were assured by the scrapyard that this was ok. Fitted it and it runs fine in 2wd but in 4wd makes alarming noises and pulls heavily to the right. Suspected that there was a mismatch between the replaced front and the original rear axles so ordered the transfer box and rear axle from the same scrapyard and supposedly the same vehicle that the front axle came from. They arrived but the back axle was non ABS so clearly wasn't from the same vehicle. Having fitted these (as directed by the scrapyard) I still have the same problem. Thoughts please?
16 Dec 2011 11:24 - 16 Dec 2011 11:25 #28338
Replied by mlines on topic Re: Jimny veering wildly when in four wheel drive
Hi,
As the first Jimnys were around S and T reg,. I am not sure what vehicle you are refering to when you mention J reg?
The question around this one will be "Auto" or "Manual"
Last edit: 16 Dec 2011 11:25 by mlines.
- DavidMitchell
16 Dec 2011 11:28 #28339
by DavidMitchell
Replied by DavidMitchell on topic Re: Jimny veering wildly when in four wheel drive
Sorry, its a private plate! :blush: It's a 2001 and its manual
16 Dec 2011 11:33 #28341
The issue with axles is that the ratio changes for Auto cars and Manual cars. Therefore the axles have to match. You either need front and rear Auto axles or front and rear manual axles.
The following user(s) said Thank You: DavidMitchell
16 Dec 2011 14:27 #28357
by facade
Replied by facade on topic Re: Jimny veering wildly when in four wheel drive
The easiest solution here would be to remove the dust seals around the spheres, remove the kingpins and pull the hubs off, and the halfshafts too, then remove the front differential.
Then remove the same from your old axle and swap the differential onto the car, I'd try and swap both the hubs and halfshafts over too, so you have your old axle insides with a "new" casing.
- DavidMitchell
16 Dec 2011 14:50 #28358
by DavidMitchell
unfortunately the old axle has been sold for scrap as the "mechanic" who did the job said it was fine!
Time to create page: 1.430 seconds
