Help: reversing lights not working!?
  • Back in Black
11 Dec 2011 14:44 #27871 by Back in Black
Help: reversing lights not working!? was created by Back in Black
Hi,
Noticed my reversing lights are not working, I've checked and swapped bulbs, checked all fuses and all connections that I can find - no joy!!
Does anyone have any tips please.
Should have been getting wet and cold striping rear brakes not f4nnying around with the reversing lights.
  • p1ngu32
11 Dec 2011 18:58 #27898 by p1ngu32
Replied by p1ngu32 on topic Re: Help: reversing lights not working!?
Well hopefully its not the switch because thats in a really stupid place on top of the gear box! Have you checked to see if you are getting any kind of power to the bulb holders?
  • jo king
11 Dec 2011 19:06 - 11 Dec 2011 19:08 #27899 by jo king
Replied by jo king on topic Re: Help: reversing lights not working!?
Have you tested the contacts where the bulb goes with it in revers if no joy ..Get under and test the continuity of the plug which leads in to the gearbox. Make sure its in reverse.
Last edit: 11 Dec 2011 19:08 by jo king.
  • Back in Black
11 Dec 2011 19:17 #27905 by Back in Black
Replied by Back in Black on topic Re: Help: reversing lights not working!?
Hi.
There's no power coming through to the bulbs.
The switch on the gear box, is that right on top of the box just visible on the passenger side when looking in the engine bay?
  • p1ngu32
11 Dec 2011 19:29 #27908 by p1ngu32
that will be it, it has a white connector plug about 3 inches from it.
  • jo king
11 Dec 2011 19:34 - 11 Dec 2011 19:39 #27911 by jo king
the passenger side of the box connecter will be the emmisions sensor the one your after is on the drivers side near the top esy access from underneath ;) chain drivern engine
Last edit: 11 Dec 2011 19:39 by jo king.
Time to create page: 0.156 seconds
