Transmission casing Drain plugs
  • wanderinstar
14 Dec 2011 18:38 #28162 by wanderinstar
Replied by wanderinstar on topic Re: Transmission casing Drain plugs
Cheers Gary,but went to local tool shop.They had rachets for about £30-£40.But managed to get a T-bat for £7. Put about a foot of pipe on it and I think it should do the trick.All I want now is a few days of dry weather.
Got a few jobs to do before New Years Eve. N/side kingpin bearings, 2" spring spacers and associated bracketry and all oils to change.
Ian.
  • supergaz
14 Dec 2011 19:45 #28170 by supergaz
Replied by supergaz on topic Re: Transmission casing Drain plugs
Id love to do some work on mine, but cannot get it in my garage and it's to cold!
I might have to take it upto a mates workshop so I can have a day on it.
My STUPID idea giving it so much lift!
Things to do ----paint cage, fit arches, rear diff/locker, n/s/r wheel bearing, rock lobster, paint and weld ora front winch bumper then replace all fluids, remove rear springs and fit spring clamps, signwriting and window tints.
And now looks like i'm working between crimbo and new yr :-(
I'll fit ur lift, kingpins and oils if you do all mine! ;-)
  • wanderinstar
14 Dec 2011 20:33 #28196 by wanderinstar
Haha.Oh I forgot those transfer box brackets as well!!
  • goatboy
15 Dec 2011 11:32 #28223 by goatboy
Replied by goatboy on topic Re: Transmission casing Drain plugs
make sure you have a blowtorch or similar to hand.
Those drain plugs can be very tight/gunged up but a bit of heat I have found loosens them up nicely everytime without rounding the hole off...
  • Gromit
23 Dec 2011 19:33 #29120 by Gromit
Replied by Gromit on topic Re: Transmission casing Drain plugs
wanderinstar wrote: Cheers Gary,but went to local tool shop.They had rachets for about £30-£40.But managed to get a T-bat for £7. Put about a foot of pipe on it and I think it should do the trick.All I want now is a few days of dry weather.
Ian.
Hope you have got it all done Ian, don't want a breakdown on your first outing :-)
  • wanderinstar
23 Dec 2011 20:47 #29127 by wanderinstar
Haha, yes got all oils changed and kingpin bearings on n/side done. Just got the 2"spring spacers to fit if its fine tomorrow.If not then next week.
Ian.
Time to create page: 0.173 seconds
