how to check snorkel
- kyrris
05 Dec 2011 00:42 #27274
by kyrris
how to check snorkel was created by kyrris
If you put your hand over the snorkel should the engine die or should it just drop RPM? Or is there another way to test your snorkel?
- myers647
05 Dec 2011 06:26 #27277
by myers647
Replied by myers647 on topic Re: how to check snorkel
Hi mate put a plastic bag over it and if the engine dies then it's working.
James
James
- darthloachie
05 Dec 2011 08:40 - 05 Dec 2011 08:40 #27283
by darthloachie
Replied by darthloachie on topic Re: how to check snorkel
drive into deep water - if engine dies then it doesn't work ! :laugh: :laugh: :laugh:
Last edit: 05 Dec 2011 08:40 by darthloachie.
- kyrris
06 Dec 2011 01:23 #27349
by kyrris
Replied by kyrris on topic Re: how to check snorkel
Thanks James, if the engine does not die but just drop some rpm should I start using silicone on the joints?
I am most definitely not driving into deep water :laugh: but is the easiest way I give you that :laugh:
- g187eev
06 Dec 2011 21:39 #27423
by g187eev
Replied by g187eev on topic Re: how to check snorkel
we always silcone the joints on our challenge trucks. you should be able to stool the engine by putting your hand over the intake it it is sealed correctly.
RB
RB
- aniesigh
06 Dec 2011 22:12 #27428
by aniesigh
Replied by aniesigh on topic Re: how to check snorkel
if it doesnt stall and you are struggling to find where its leaking try spraying brake cleaner around the joints one at a time, if it revs up that ones leaking
Time to create page: 0.262 seconds
