How do you "lock up" the fan with cable ties?
  • Nobby22
06 Dec 2011 09:11 #27360 by Nobby22
v8dougie wrote:
Nobby22 wrote: p.s. when i start the engine from cold should it start with a noticeable "roaring" sound and then slowly die away to a more normal tone?
Nobby
Yes it should! If it is doing this then I would have thought it is operating correctly.
The reason i asked this is because i DONT think it is makeing the sound it should. Certainly not like my old Grand Vitara, that made a realy noticeable roaring sound when first staryed. I carnt remeber if that was a viscous fan or electric. The Jimny just sounds the same all the time. Thats whats makeing me think it is the fan.
Nobby
06 Dec 2011 12:38 #27371 by kirkynut
I've not paid much attention to the viscous fan before so I've not been able to answer hut I'm gagging to know if this solves it!
  • rjd1
06 Dec 2011 19:17 #27404 by rjd1
the pulley on engine in front of fan has holes in place cable tie`s through the pulley then the fan
checked the day but no pic` s hole`s are big enough for tie`s to go through
hope this help`s
  • Nobby22
06 Dec 2011 20:19 #27411 by Nobby22
rjd1 wrote: the pulley on engine in front of fan has holes in place cable tie`s through the pulley then the fan
hope this help`s
Thanks again. I had considered this but didnt have long enough cable ties at the time to give it a go. I will do it tommorow and report back. Fingers crossed :unsure:
Nobby
  • rjd1
08 Dec 2011 18:22 #27554 by rjd1
how did you get on???????
  • Nobby22
09 Dec 2011 09:04 #27612 by Nobby22
Well......... I tied up the fan as you said. Initialy it didnt sound any different, on tick over. Once i took it out for a spin you could clearly hear the fan spinnig up. Sounds very meaty :) , a real roaring sound. Certainly its never sounded like that before. So i think its a good bet the fan has gone. I will take it out for a long trip this evening or tommorow. If it doesnt heat up then we know its the fan at fault. Fingers crossed :unsure:
Cheers rjd1 for your help and advice ;)
Nobby
