Power steering belt
- Gromit
30 Nov 2011 14:04 #26937
by Gromit
Power steering belt was created by Gromit
How do you adjust the power steering belt as mine is screaming. I can see that there are two bolts on the pulley but what do you do to adjust the pulley ?
30 Nov 2011 20:24 - 30 Nov 2011 20:25 #26976
by facade
Replied by facade on topic Re: Power steering belt
On my twin cam you undo the two pinch bolts and try to rotate the whole assembly, there is a small hexagonal hole in the centre for this purpose, but if you can get a tool into it without removing the pulley first you are a better mechanic than I
Last edit: 30 Nov 2011 20:25 by facade.
Time to create page: 0.071 seconds
