rear bushes - poly or oem ?
- jonplace
14 Mar 2010 14:40 #2693
by jonplace
rear bushes - poly or oem ? was created by jonplace
the rear axle bushes are knackered and i'm wondering whether its worth going down the poly bush route or just stick with standard suzuki oem ones ? any thoughts / opinions ?
cheers
cheers
- richard
14 Mar 2010 15:54 #2695
by richard
Replied by richard on topic Re:rear bushes - poly or oem ?
not realy got a clue but i'v put poly on front dampers and as i put on the top nut they just squashed flat as it got trite,
14 Mar 2010 17:43 #2697
Replied by mlines on topic Re:rear bushes - poly or oem ?
The general opinion is that the Suzuki ones give a softer ride and more articulation as the Poly ones tend to be solid whilst the Suzuki ones have slots cut in them that have to be positioned correctly in accordance with the workshop manual
- Baz2236
14 Mar 2010 18:16 #2701
by Baz2236
Replied by Baz2236 on topic Re:rear bushes - poly or oem ?
I got super pro bushes on mine front n rear and it is a stiffer ride articulation is alright maybe lost a little but not much.
- jonplace
15 Mar 2010 11:04 #2704
by jonplace
Replied by jonplace on topic Re:rear bushes - poly or oem ?
well i've had mixed responses about the poly ones, most people suggesting they're too firm and limit travel.
In the end i bought a set of suzuki ones from rhino ray at £15 each. i thought it was a bit steep till i rang the local dealer who want £23 each !!!! :ohmy: yikes
cheers all for feedback
