Standard Jimny springs
- TomDK
26 Nov 2011 19:22 #26670
by TomDK
Standard Jimny springs was created by TomDK
Hi
Can anyone tell me what specifications are on standard Jimny springs, that is total unsprung length and spring rate.
I'm considering these springs, www.lowrangeoffroad.com/index.php/builde...id-coil-springs.html but don't know what length and spring rate to buy. You may know that I'm planning on a Cosworth V6 or perhaps Lexus V8, so this should be taken into consideration also.
27 Nov 2011 15:06 #26723
by SpeeLaT
Replied by SpeeLaT on topic Re: Standard Jimny springs
I just replaced my springs with Monroe Adventure's (Standard). The old springs I have are 280 mm rear and 330 mm Front. I am sure they have sagged the new standard springs lifted the car a fair bit. I couldn't get my hand between the rear tyre and the top of the arch palm side on top to bottom. Now my hand has plenty of room.
- Cocopolo
28 Nov 2011 10:26 #26781
by Cocopolo
Replied by Cocopolo on topic Re: Standard Jimny springs
Stock springs are front 33cm, rear 29cm for the gasoline older version
on newer gasoline versions (VVT engine), front ones are 35cm long.
The rate, for the stock springs, should be around 120lbs/inch
Hope this helps
Hope this helps
- Black Toy
14 Jun 2012 12:44 #42340
by Black Toy
Replied by Black Toy on topic Re: Standard Jimny springs
Time to create page: 2.638 seconds
