Aerial
  • grumpy22
23 Nov 2011 20:38 #26441 by grumpy22
Aerial was created by grumpy22
Bit like the grand old duke of York my aerial is neither up not down. Its been soaked in plus gas and penetrating oil for well over a month and I want to have a bash at returning it to full up and down capability!
Any suggestions as to the best way forward?
  • Licksan
23 Nov 2011 21:19 #26446 by Licksan
Replied by Licksan on topic Re: Aerial
I had the same trouble and sorted last weekend with penetrating oil and a lot of careful twisting, pulling and pushing, lots more oil, more twisting and pulling! Eventually got it up! Ooo Err Misses!! :laugh:
Once fully extended I lightly rubbed it with some mild sand paper to remove the rough patches causing it to bind, wiped it down and oiled it up.
Don't be too heavy handed as it will bend very easily so you have pull it in the right linear direction. Do a bit and then oil it a bit etc working it in and out and it should come free. Took me about 30 mins and you do have to pull quite hard. :P
  • grumpy22
23 Nov 2011 22:10 #26452 by grumpy22
Replied by grumpy22 on topic Re: Aerial
Cheers for that, just a thought what's the fully extended length? Mines stuck up about 15 inches so should I pull it out further or push it in?
Geez this is an odd conversation.
23 Nov 2011 22:22 #26455 by facade
Replied by facade on topic Re: Aerial
Never seen a whole one. Every one I've seen is about 6" long, because it got snapped off, and the broken top section gets jammed into what is left.
A new one is £1,000,000 from Suzuki, and the hard top one is different to a convertible, so whatever you do, don't break it ;)
  • grumpy22
23 Nov 2011 22:33 #26456 by grumpy22
Cheers for that ;-)
You sound like you've had more of the amber stuff than I have!
  • darthloachie
24 Nov 2011 08:01 #26467 by darthloachie
Replied by darthloachie on topic Re: Aerial
we've got a bendy thin steel one that is taped to the roll cage
Time to create page: 0.279 seconds
