HELP! - Disc backing plate bolts removal
- goatboy
23 Nov 2011 11:44 #26395
by goatboy
Replied by goatboy on topic Re: HELP! - Disc backing plate bolts removal
great thanks Martin.
I'll have a play tonight.
I just got one of these too
www.diy.com/diy/jsp/bq/nav.jsp?action=de...e=sockets___spanners
Might give better purchase on the bolt but I probably won't be able to even get it on....
24 Nov 2011 10:51 #26473
by kirkynut
Replied by kirkynut on topic Re: HELP! - Disc backing plate bolts removal
You don't need to undo those four bolts to get to the cv joint. Just remove the Freewheeling hub, take the circlip off the end of the shaft, take all the brakes off including the disc, which is where you photo appears to be at, remove the swivel seal by undoing the thousand 10mm bolts, then remove both kingpins by undoing the four 12mm bolts on each, pull the whole assembly off leaving a clean cloth on the ground to catch the lower kingpin as it falls out. Then pull the shaft out the axle and the cv on it or if they've separated it'll be on the floor or in the steering knuckle assembly still.
I would replace the axle oil seal whilst you have it apart as it costs less than £2 and you'll be annoyed if you find its damaged and leaks once you've put it all back together.
The following user(s) said Thank You: goatboy
- goatboy
24 Nov 2011 11:48 #26480
by goatboy
Cheers Kirky, sounds like you and Martin have suggested the same thing.
It shall be tonights fun! I'll let you know how I get on.
- goatboy
25 Nov 2011 07:02 #26538
by goatboy
Got the hubs off!
The king pins were stuck pretty fast. Bottom one took about 45minutes of hammering and heating and drilling and whacking and swearing and sweating and bleeding and more hammering but I got there in the end. (this was all after removing the 4 bolts.)
King pin bearings very rusty and dry, CV joint still intact with a little play but nothing too major.
25 Nov 2011 13:34 #26550
by kirkynut
Crickey, I didn't think of the kingpins being seized too! I had that on a replacement front axle I bought for mine. Letting wd40 soak helps but that involves patients which I have little of when working on cars!
What's up with your cv though?
