Problem after doing lift
- kevant
13 Mar 2010 08:07 #2675
by kevant
Replied by kevant on topic Re:Problem after doing lift
Standard jimny transfer box does not have a neutral gear which is a shame but i am going to change it in the future when funds allow anyway but i think i may be getting some progress with my problem. Yesterday i checked the rear drums and as i thought they were spot on no probs at all so i took another look at the prop and i dont know why i never spotted this before but it looks like one of the balancing weights has dropped off it must have happened when we took the old arms off because after 10 years these bolts take a bit off shifting so i am taking the prop to a local firm next week to have it balanced and fingers crossed it should sort it out i will let you know how i get on.
- kevant
17 Mar 2010 18:47 #2723
by kevant
well i picked my propshaft up today and no problem with it no weights missing and it was perfectly balanced so its back to the drawing board. since i have been running around all week on front wheel drive only i have had no vibrations and as soon as i put the rear prop back on back came the vibration. Ideas anyone ?
- Jamie
17 Mar 2010 18:54 #2724
by Jamie
Replied by Jamie on topic Re:Problem after doing lift
Is there any play in the rear diff pinion bearing?????
When you lift a Jimny it pull's the diff nose up, Is there enough
oil in the diff so the pinion bearing is not running dry??????
Are the wheel's mounted correctly??? i.e is there any crap in the drum face or
on the rim mounting face???
Hmmmmm i shall keep racking my brain for you pal!!
Jamie
Jamie
- jonplace
17 Mar 2010 20:15 #2726
by jonplace
Replied by jonplace on topic Re:Problem after doing lift
if you've been using the car without the rear prop attached the rear half shafts / diff etc will still be turning (just under no load). i would still say look at the prop or angles of the prop / UJ's. do you know anyone else with a jimny, maybe you could borrow their prop and test
or fill the back of the jimny with bags of sand to lower it back to normal hieght, see if cures :lol:
keep us posted on this one
- Thank you received: 115
- kevant
18 Mar 2010 07:58 #2732
by kevant
In Morecambe Lancs just next to Lancaster
Time to create page: 0.158 seconds
