Problem after doing lift
- kevant
08 Mar 2010 18:25 #2617
by kevant
Problem after doing lift was created by kevant
Have just finished my 2 1/2" Rhino Ray lift and i can no longer select low ration on my transfer box also i have vibration when accelerating does anyone have any ideas what it might be.
08 Mar 2010 18:39 #2619
Replied by mlines on topic Re:Problem after doing lift
I would guess that the position of the transfer box is now wrong in some way, is it a spring lift or body lift.
If the transfer box has moved then the lever may not fully pull back. This could also cause the prop to wobble (out of balance)
- Garry
08 Mar 2010 18:54 #2620
by Garry
Replied by Garry on topic Re:Problem after doing lift
tups of here and my friend has the Rhino Ray 2 1/2 inch spring lift, no problems with it
- kevant
08 Mar 2010 19:50 #2624
by kevant
Replied by kevant on topic Re:Problem after doing lift
yeah its the full radius arms and springs new shocks and to be honest the quality of rhino rays gear is excellent so i have no doubt that its something i have done prob like you say martin i have moved the transfer box but does anyone any know if i need prop spacers as i was wondering if they were at full extent would they put pressure on the transfer box and knock it out of balance or would it all settle down after a week or so
- jonplace
08 Mar 2010 20:31 #2626
by jonplace
Replied by jonplace on topic Re:Problem after doing lift
strange one. i have the same lift kit on mine without issue. no prop spacers required. the transfer box is not affected by a suspension lift. what do you mean when you say you moved the transfer box ? must be something to do with this
does the lever not pull all the way back ?
- kevant
08 Mar 2010 20:43 #2628
by kevant
no the lever does not pull all the way back i can only select normal 2 wheel drive and 4 hi not 4 lo and i also have a constant vibration when driving. I noticed yesterday that the rear prop had slipped out of the transfer box a little when we put the new arms springs etc on the back so i thought nothing of it and just pushed it in again on reflection it could have moved then and caused everything to go pear shaped but when we put the front on today i checked everything and it all looked fine so its strange.
Time to create page: 0.095 seconds
