Engine oil starvation
  • William
18 Nov 2011 18:26 #26031 by William
Engine oil starvation was created by William
Is there a possibility that descending (or ascending) a steep slope in a Jimny would result in engine oil starvation due to the oil pump pickup in the sump not being submerged in the oil? Or is the sump designed in such a way that the oil pickup would always be submerged in the oil, no matter how steep the angle of descent?
18 Nov 2011 18:51 #26035 by mlines
Replied by mlines on topic Engine oil starvation
It has a shaped sump to create a deep but narrow pool around the pickup
-- Sent from my HP TouchPad using Communities
The following user(s) said Thank You: William
19 Nov 2011 01:07 #26081 by kirkynut
Replied by kirkynut on topic Re: Engine oil starvation
I've had mine as some horrific angles in every direction with not a single flicker from the oil light. So as Martin says the pick up must be always coveted.
I must admit that if stuck at an angle waiting to be pulled out of the mess I got myself in, I do turn it off until help has arrived, just in case!
  • William
19 Nov 2011 03:15 #26085 by William
Replied by William on topic Re: Engine oil starvation
Thanks Kirkynut,
Its bad enough being caught in a bad situation, but with a seized engine too......!
Thanks for the responses. I'd hate to damage my favourite car.
19 Nov 2011 08:57 #26090 by kirkynut
Even if this is a worry for you, don't be tempted to overkill the oil to compensate. This can cause issues of it's own.
I find Jimny engines not to use oil unless really old so oil level remains good.
Time to create page: 0.200 seconds
