Cb radio instalation.
- supergaz
25 Nov 2011 20:33 #26580
by supergaz
Replied by supergaz on topic Re: Cb radio instalation.
Id go straight to the battery with a in-line fuse as close to the battery as possible. Better dig mine out and think of fitting it.
- Nobby22
25 Nov 2011 20:44 #26585
by Nobby22
Replied by Nobby22 on topic Re: Cb radio instalation.
Seeing as iam a novice with car elctroincs, when you say as close as possible do you mean in terms of attaching it to the cars wiring as close as possible? When people say "attach it to the battery" i think of litteraly attaching it straight to the battery. Can it be attached to the correct wireing leading to the battery? Also it has a fuse built in to the wiring already, result
Nobby
Nobby
25 Nov 2011 20:48 #26589
by Halford
Replied by Halford on topic Re: Cb radio instalation.
- Nobby22
25 Nov 2011 20:55 #26591
by Nobby22
. Thats something i have be thinking about for ages. I was going to try the hole behind the battery, under the steering consol, this ways is much easier. But that was for my dixie horns :laugh: still havnt got them wired up either
Nobby
Thanks halfordHalford wrote: good guide thread here for running wires from the engine compartment into the cabin.
Nobby
- supergaz
25 Nov 2011 20:59 #26593
by supergaz
When we attach a load to a battery, it is always best to have as small as possible length of cable between the battery terminal and the fuse, so in the event of a short it will minimise the risk of the worst. Also I find it frustrating when people just twist wires/ trap them to the battery terminal instead of using the correct terminal crimps.
My jimny was a fire in the making when I got it, Next daylight I was out stripping all the gadgets, spot lights, CB radio, Winch ect
Now i've no worries about all my wiring.
25 Nov 2011 21:31 - 25 Nov 2011 21:35 #26598
by Halford
Nobby, this is what I'm looking to do - fit a 4 Way Blade Fuse Box direct to the battery
from which to run up to 4 feeds eg. CB, aux power socket, - even air horns :lol:
probably best to get your friend to wire it up properly, then you can just add what you want when ready
check out cbsonline for the type of bits required
Attachment 4WayBladeFuseBox.jpg not found
Attachment bladefuse.jpg not found
Last edit: 25 Nov 2011 21:35 by Halford.
Time to create page: 0.250 seconds
