Rough Running Jimny
- p1ngu32
08 Nov 2011 19:54 #25367
by p1ngu32
Rough Running Jimny was created by p1ngu32
Got a bit of a problem with a friends jimny, i did the head gasket on it about 10k+ miles ago had the head skimmed etc, after the radiator burst and the gasket got cooked. One year on and its now started running rough, i swapped the cam sensor and coil packs with mine and no change. If i disconnect injector 2 or 3 individually it runs exactly the same as it does with them plugged in. I would have done a compression test on it but the pipe on my tester isn't long enough to reach the plug hole in the head.
My thoughts are that the head gasket has gone again but between cylinder 2 and 3 this time. Any input appreciated before i go start taking it apart again!
video of the problem
Thanks
Richard
Thanks
Richard
- 247sniper
27 Dec 2011 22:29 #29336
by 247sniper
Replied by 247sniper on topic Re: Rough Running Jimny
Can you carry out a cylinder leakage test at all? That will definitely confirm weather it is head gasket failure for sure.
Steve.
Steve.
- p1ngu32
12 Jan 2012 20:06 #30777
by p1ngu32
Replied by p1ngu32 on topic Re: Rough Running Jimny
Fixed this a while ago, it was the head gasket, the sealing rings round cylinders 3 and 4 were in bits, the new gasket ive fitted seems much better made than the last one i was supplied so fingers crossed it lasts longer.
- 247sniper
13 Jan 2012 06:25 #30798
by 247sniper
Thanks for letting us all know.
Steve.
Steve.
Time to create page: 0.150 seconds
