engine change
- russell
30 Oct 2011 20:13 #24851
by russell
engine change was created by russell
hey guys im awaiting a new engine for my jimny its a sohc 1.3 any ideas on what there like to change and any handy tips?
- aniesigh
30 Oct 2011 21:42 #24871
by aniesigh
Replied by aniesigh on topic Re: engine change
4 bolts on the bellhousing plus little 10mm nut that holds the dust shield on, 2 engine mounts, 2 radiator hoses, air inlet pipe, throttle cable, exhaust down pipe (2 bolts, possibly rusted in!) main power wires on starter motor, couple fuel lines, then unplug all the wiring plugs. think thats about it!
installation is the reverse of removal
fairly straight forward stuff, plenty of room to get to most of it apart from some stuff on the drivers side of the motor.
- supergaz
30 Oct 2011 21:45 #24873
by supergaz
Replied by supergaz on topic Re: engine change
Before installing the new engine its definately worth changing the timing belt.
- martysmith
31 Oct 2011 21:29 #24940
by martysmith
Replied by martysmith on topic Re: engine change
i agree it will only take a few mins ..............and if it was me i would fit a new clutch too will save time in futuresupergaz wrote: Before installing the new engine its definately worth changing the timing belt.
- russell
01 Nov 2011 17:43 #24969
by russell
Replied by russell on topic Re: engine change
yea id alwaysfit timeing belt and clutch as matter of course it looks prety straight forward to me was just checking if there was any hidden gremlins when it can to changeing them, but thanks for the help once again guys
- martysmith
01 Nov 2011 18:07 #24970
by martysmith
you should have nee botha mate good luckrussell wrote: yea id alwaysfit timeing belt and clutch as matter of course it looks prety straight forward to me was just checking if there was any hidden gremlins when it can to changeing them, but thanks for the help once again guys
Time to create page: 0.166 seconds
