Universal Joints
- viciouspenguin
26 Oct 2011 12:22 #24525
by viciouspenguin
Universal Joints was created by viciouspenguin
I need to get a part number or alternative for the 25mm uj.
- darthloachie
26 Oct 2011 15:26 #24547
by darthloachie
Replied by darthloachie on topic Re: Universal Joints
don't know the number but I think there is a Mitsubishi one thats the same
26 Oct 2011 15:44 - 26 Oct 2011 15:47 #24549
by Obarno
Replied by Obarno on topic Re: Universal Joints
The 25mm joint from Blueprint is part number ADK 83901 and the 23mm is ADK 93902
You can get these from Camskill, or of course you can get them from the Big Jimny Store!
Last edit: 26 Oct 2011 15:47 by Obarno.
17 Jan 2019 08:22 - 17 Jan 2019 08:29 #200939
by Bosanek
Replied by Bosanek on topic Universal Joints
Does anyone know if the original Suzuki universal joint (P.N. 27200-83812) comes with a grease nipple or if it is "sealed for life"?
If it comes with a grease nipple, does the nipple attach to the core body of the joint or to the face of one of the four cups?
EDIT: I am asking this because I found a German ad where the seller was selling brand new Suzuki universal joint under this part number, and the joint came with c-clips and a grease nipple.
However, as far as I know, all factory fitted universal joints on all Jimnys ever produced were without grease nipples.
Could it be that Suzuki is alternating between greasaeble and sealed joint models under the same part number depending on the production batch (i.e. depending on who they source it from at a particular point in time)?
Last edit: 17 Jan 2019 08:29 by Bosanek.
- Max Headroom
- Banned
- Thank you received: 217
17 Jan 2019 08:45 #200940
by Max Headroom
Replied by Max Headroom on topic Universal Joints
I'm almost certain the ones Martin sells in the BigJimny shop come with grease niples,
I can't however answer your question about what was original specification
23 Jan 2019 07:32 #201480
by kirkynut
Replied by kirkynut on topic Universal Joints
Just get Blueprint ones from Martin. I got them locally as I couldn't wait for postage but they're the same and have nipples.
A right bugger to change though.
Time to create page: 0.215 seconds
