Is it time for a cam belt change
- v8dougie
28 Oct 2011 07:47 #24613
by v8dougie
Replied by v8dougie on topic Re: Is it time for a cam belt change
Not denying with the rad out you would have more room, but I did not find it a struggle at all. If your coolant is due to be changed, then definitely take it out, if like mine it was not, then try it without removing it. If you find you struggle, you can always pop it off during the belt change.
Cheers
Cheers
28 Oct 2011 08:16 #24614
by facade
When I did the 200tdi Defender pretty much the whole engine has to come apart: at least it doesn't get muddy water on it when you go for a swim.
Not looking forward to doing the RAV4, looks like an all day job.
Replied by facade on topic Re: Is it time for a cam belt change
grumpy22 wrote:
done quite a few belts and they've all been messy fiddly jobs - even on landies. just poor tight access.
- grumpy22
28 Oct 2011 10:33 #24615
by grumpy22
Replied by grumpy22 on topic Re: Is it time for a cam belt change
parts ordered from japparts. I like the idea of trying with the rad in and taking it out if needed. I always find refilling a cooling system a real pain! so the less I disturb the better.
cheers all
G
cheers all
G
