Is it time for a cam belt change
  • Topper
26 Oct 2011 09:42 #24510 by Topper
Is it time for a cam belt change was created by Topper
Hi
I have been told that the cam belt on my 2004 jimny O2 is due for a change at 6 years..so its due now with 34,000 miles on the clock,
Is it a big job?...easy DIY ?..im no mechanic
Topper
26 Oct 2011 11:37 #24522 by mlines
Only the G13BB engines have cam belts. I see yours looks like a Spanish Soft-top, therefore there is a chance it has a G13BB engine in it, all other models changed to M13AA engines in 2001. Its worth a check of which engine you have first.
You have to take the front covers/belts/pulleys off the engine, so it includes removing the radiator etc. You also need to align the timing marks properly when you re-assemble.
Perhaps a touch ambitious if you have no experience.
  • grumpy22
26 Oct 2011 15:09 #24543 by grumpy22
Replied by grumpy22 on topic Re: Is it time for a cam belt change
I'm going to be doing mine in the next few weeks. I'm fairly competent but due to the amount of faff would gladly out source the job
  • happypig
27 Oct 2011 07:11 #24575 by happypig
Replied by happypig on topic Re: Is it time for a cam belt change
mlines wrote: Only the G13BB engines have cam belts. I see yours looks like a Spanish Soft-top, therefore there is a chance it has a G13BB engine in it, all other models changed to M13AA engines in 2001. Its worth a check of which engine you have first.
How do I check which engine I have in my 2001 hardtop as I'm having the same thought ?
27 Oct 2011 12:06 #24583 by mlines
The definitive way is to look at the VIN number. JB33 is G13B, JB43 is M13A
At a quick glance the CAM belt cover on a G13BB is plastic, the CAM Chain cover on an M13A is metal.
  • happypig
27 Oct 2011 13:03 #24584 by happypig
JB43. Sorted, thanks.
Time to create page: 0.168 seconds
