Wheel Arch Liners
- doncarlyon
26 Oct 2011 08:55 #24501
by doncarlyon
Wheel Arch Liners was created by doncarlyon
What do people use as wheel arch liners when the arches have been chopped?
- supergaz
26 Oct 2011 14:11 #24537
by supergaz
Replied by supergaz on topic Re: Wheel Arch Liners
I've nothing, Jimnys just going commando, Will need regular thorough powerwashing after playing though.
26 Oct 2011 15:52 #24551
by Obarno
Replied by Obarno on topic Re: Wheel Arch Liners
I used some unbreakable plastic sheeting, something like perspex (only because I had a big sheet!) I made a template and then cut the plastic to fit. I fixed it in place, and therefore its now removeable, with some 6mm rivnuts. I found that without them the mud and muck went everywhere!
- trextr7monkey
26 Oct 2011 16:52 #24553
by trextr7monkey
Replied by trextr7monkey on topic Re: Wheel Arch Liners
We have made a variety of arch extensions using ABS- it contains some rubber in the material so is less likely to get damaged by flying stones and is the material of choice for dash boards and kick panels on a wide variety of transport cars, buses, trains, planes and cars.
Main attraction for DIY purposes is that it is easlily worked with normal tools and can be line bent over a hot wire to give a tight crease or can be rolled over the edge of a work top or pipe/ broom shank etc to give a smooth radius, once you have made your chosen profile it can be nipped and tucked to follow shape of wing etc. It can also be vac formed to make battery covers etc too
It should be possible to make a rear parcel shelf from it too.
hth
Mike
hth
Mike
Time to create page: 0.147 seconds
