ABS ring and sensor removal ?
  • mick1
24 Feb 2010 11:07 #2448 by mick1
ABS ring and sensor removal ? was created by mick1
Hi, I have started to do my king pin bearings and have encountered something which is not in the guide. I think it is the ABS ring and sensor - does anyone know how to remove this so that I can take off the backing plate and the hub and get on with the job of changing the bearings.
Any help, advice, photos etc would be VERY gratefully received! Thanks Mick
  • Jamie
24 Feb 2010 13:29 #2451 by Jamie
Replied by Jamie on topic Re:ABS ring and sensor removal ?
Hi Mick,
I did mine a few week's ago and didn't bother taking the ring off
just took the sensor off.
The sensor is a 10mm bolt and gently prize it out mine was
a bugger to come out as it was a really tight fit.
Is this the bolt you mean????
  • mick1
24 Feb 2010 14:16 #2454 by mick1
Replied by mick1 on topic Re:ABS ring and sensor removal ?
Thanks for getting back to me Jamie - there is a serrated cog between the backing disc plate and the hub - I can't get the ring spanner in there to remove the two bolts - how did you manage to do that?
Mick
  • Jamie
24 Feb 2010 15:15 #2456 by Jamie
I didn't bother taking it off i don't think you need to
i also left the backing plate on you don't really need to remove it.
My hub looked like this when i took it off!!!!
  • mick1
24 Feb 2010 15:21 #2457 by mick1
Yeah that's the cog I was talking about. I'll do as you suggest and hope it goes as well for me as it did for you! Thanks for the photo, it's a big help.
Mick
  • Jamie
24 Feb 2010 19:21 #2462 by Jamie
No Prob's pal
Let me know how you get on!!
Jamie
Time to create page: 0.158 seconds
