trans oils
25 Oct 2011 15:30 #24454
by facade
Replied by facade on topic Re: trans oils
Mine has molyslip in, in an attempt to quieten the input shaft bearing.
Doesn't work
I imagine other snake oils work equally badly
Doesn't work
- grumpy22
25 Oct 2011 16:11 #24456
by grumpy22
Replied by grumpy22 on topic Re: trans oils
so can I just buy 5L of GL4 and use that in everything? (except the engine!!)
- adamatdraycott
25 Oct 2011 16:18 #24459
by adamatdraycott
Replied by adamatdraycott on topic Re: trans oils
Just buy what the book says... or is that too easy?
- grumpy22
25 Oct 2011 18:43 - 25 Oct 2011 18:44 #24471
by grumpy22
far too easy, and not quite what facade says.
thanks for the input though and I am thinking that your advice is probably the best option
G
ps I'm certainly no expert
G
Last edit: 25 Oct 2011 18:44 by grumpy22.
- Smoggy
25 Oct 2011 19:09 #24474
by Smoggy
Replied by Smoggy on topic Re: trans oils
Beware though, especially on older models the plugs may not have been removed for some time, and easily round off. For this reason it may be a good idea to slacken off the filler plug before attempting to remove the drain plug or you may get it emptied and not be able to refill!
- grumpy22
25 Oct 2011 19:14 #24475
by grumpy22
good point, I've been soaking the plugs in plus gas fow a few days so hopefully they'll come out easy-ish! I like the idea of opening the fill before the drain, very good idea
