Seized bolts holding hub !!!!
  • hathome
24 Oct 2011 11:50 - 24 Oct 2011 11:51 #24326 by hathome
Seized bolts holding hub !!!! was created by hathome
Hi All
Finally took a couple of days off to sort the King Pin Bearings - Was all going well until I got to the four bolts holding the disc backplate & hub to the knuckle. These are so baldly corroded that the size is now somewhere between 14 & 13mm and I'm unable to shift them!! :( :( Anyone with experience on this who can offer help would be much appreciated.
PS - Martin (mlines) - Thanks for all your help so far.
Last edit: 24 Oct 2011 11:51 by hathome. Reason: spelling
  • adamatdraycott
24 Oct 2011 12:25 - 24 Oct 2011 12:28 #24328 by adamatdraycott
Replied by adamatdraycott on topic Re: Seized bolts holding hub !!!!
You don't need to un-do them.
Nor do you need to remove the disc.
If you remove the kingpins, seperate the ball joint(s) and remove the bolts holding the large hub seal, the entire hub will come off (remember to keep the pipes/wires slack) leaving the shaft in place. When you replace, point the half shaft upwards and locate the hub over the top of it, and push.
Last edit: 24 Oct 2011 12:28 by adamatdraycott.
  • doncarlyon
24 Oct 2011 15:23 #24336 by doncarlyon
Replied by doncarlyon on topic Re: Seized bolts holding hub !!!!
Just noticed today that one of mine is leaking oil again, was only repaired a few months ago :(
What is it that kills these bearings / seals?
  • hathome
24 Oct 2011 17:44 #24349 by hathome
Replied by hathome on topic Re: Seized bolts holding hub !!!!
Thanks for that - all on the bench now waiting for a good clean. Just need to source a new rear seal now for the swivel the one that came off it completely shot!!!
this job just keeps growing !!:evil:
  • hathome
24 Oct 2011 17:46 #24350 by hathome
Hoping this repair will get me through the winter at least !:whistle:
24 Oct 2011 21:01 #24390 by facade
Water. Especially muddy water. Or salty water. Or just water.
They are like Gremlins. Do NOT get them wet. ;)
Time to create page: 0.200 seconds
