Front spot lights. Pics of how you have done them.
  • martysmith
23 Oct 2011 16:26 #24281 by martysmith
20 quid a pair on ebay and outer ring can light up blue and iner is a normal white light .......not wired up yet but will show you pics when done if needed
Attachment DSC00213.JPG not found
  • ZookFastback
23 Oct 2011 17:04 #24283 by ZookFastback
Mounted to 75mm alloy nudge bar. 2 spots and 2 fogs.
[IMG
23 Oct 2011 19:24 #24307 by Halford
  • Sandez
23 Oct 2011 20:58 - 23 Oct 2011 21:00 #24319 by Sandez
I haven't posted anything up on my spotlights yet (but will soon), but as they are DIY, LED and small enough, I have installed then in the front grills. No problem with air flow and the active cooling is an added bonus
Attachment 1_2011-10-24.jpg not found
Attachment 3_2011-10-24.jpg not found
Attachment 2_2011-10-24.jpg not found
Last edit: 23 Oct 2011 21:00 by Sandez. Reason: Additional pic
  • Nelson83
24 Oct 2011 17:11 #24344 by Nelson83
Mine are bolted to a length of ali angle that i riveted to the back of the a bar. Mine are the cheap ring ones from 'frauds, they do the job at the moment, but i would like to upgrade ;-)
www.facebook.com/media/set/?set=a.444855...&type=1&l=84cb795740
  • darthloachie
24 Oct 2011 17:55 #24355 by darthloachie
Sandez wrote: I haven't posted anything up on my spotlights yet (but will soon), but as they are DIY, LED and small enough, I have installed then in the front grills. No problem with air flow and the active cooling is an added bonus
I like these - what make are they and where did you get them from?
Time to create page: 0.197 seconds
