Front spot lights. Pics of how you have done them.
  • Nobby22
23 Oct 2011 12:43 #24262 by Nobby22
Hi all
I rather like the idea on mounting some front spot lights to the front bumper or even to the roof bars. If any one has any pics of how the have done it and/or the make of the spot liights used i would be most grateful.
Thanks
Nobby
  • Dutchjimny
23 Oct 2011 14:34 #24269 by Dutchjimny
I used 2 hella's
  • p1ngu32
23 Oct 2011 14:41 #24271 by p1ngu32
I used 4 cheap ring square spotlights £15 a pair iirc. I used a piece of pipe cut to fit between the roof bars, welded a flat plate on either end drilled into the roof bars and bolted it on. Then welded the metal brackets that come with the lights to the bar.
Not a great picture but this is how they fit
  • Az1987
23 Oct 2011 14:50 - 23 Oct 2011 18:06 #24273 by Az1987
I put mind on the edge of the bonnet that way if you get them right you can swing them right down and light up the enigne bay as well, if the worst was to happen at night.
the last pics show where i run the wiring
Last edit: 23 Oct 2011 18:06 by Az1987.
  • Az1987
23 Oct 2011 14:52 #24274 by Az1987
i used 2, 6" driving lamps from Extreme 4X4
  • Az1987
23 Oct 2011 14:55 #24275 by Az1987
the last pics is who i run the wiring
Time to create page: 0.162 seconds
