Engine Warning Light
- doncarlyon
19 Oct 2011 09:43 #24009
by doncarlyon
Engine Warning Light was created by doncarlyon
Is this supposed to light up when you first turn the key?
I have a fault code which has appeared a couple of times but never triggered the light, its P0135 which is the front Lambda sensor i think.
Car seems to drive ok... just wondering if maybe the bulb has blown or if its been removed.
- Az1987
19 Oct 2011 16:39 #24044
by Az1987
Replied by Az1987 on topic Re: Engine Warning Light
Yes it should for about 20 secs then go out when started
- martysmith
19 Oct 2011 18:04 #24054
by martysmith
Replied by martysmith on topic Re: Engine Warning Light
sounds like bulb been took out .......does yours have the 16pin plug in point under dash cos you can pop round some time and i will put computer on it
- doncarlyon
19 Oct 2011 18:38 #24055
by doncarlyon
Replied by doncarlyon on topic Re: Engine Warning Light
ive got a code reader, thats how i knew it was p0135. Thanks for the offer though. I will check the bulb.
- martysmith
19 Oct 2011 18:49 #24057
by martysmith
mine does not give codes it gives fauts ! let me know if you ever need it;)
- Az1987
19 Oct 2011 19:03 #24060
by Az1987
If its P0135 it's the dtc for the heated part of the front O2 sensor. It works by getting the O2 sensor up to temp so it gives correct readings all the time if it fails the sensor will give faulty readings during warm up and could cause running problems from cold and lower MPG as the vehicle will be running poor air fuel ratio when warming up
Time to create page: 0.153 seconds
