Faulty O2 sensor, which one?
- renard38
19 Oct 2011 16:32 - 19 Oct 2011 16:32 #24043
by renard38
Replied by renard38 on topic Re: Faulty O2 sensor, which one?
Last edit: 19 Oct 2011 16:32 by renard38.
- martysmith
19 Oct 2011 17:54 #24053
by martysmith
Replied by martysmith on topic Re: Faulty O2 sensor, which one?
if you can get it plugged in to computer it will tell you bank one or bank two o2 sensor .......bank one is normally the sensor b4 the cat then bank two is after the cat though some japenese cars do reverse this but i not come across this on any suzuki as yet......hope this helps
- Az1987
19 Oct 2011 19:12 #24064
by Az1987
Replied by Az1987 on topic Re: Faulty O2 sensor, which one?
Both senors will be bank one as it is a inline 4 cylinder engine, bank 2 sensors are only used on VEE engines and it will be bank one sensor one or bank one sensor two Codes. sensor one is in the manifold sensor two is in or behind that cat it's most likely the sensor in the manifold because that's the one which take the most extreme changes in temp and the heater part always brakes down because of this and the engine ECU detects the circuit go open circuit and brings the light on.
- Fuzzoire
20 Oct 2011 04:37 #24075
by Fuzzoire
Replied by Fuzzoire on topic Re: Faulty O2 sensor, which one?
Thanks everyone, I have discovered that I cannot get the the engine warning light to flash the error code by inserting a wire into the 6pin plug under the glove box because I have a factory fitted engine immobilizer. (correct me if I am wrong anyone). Using the service manual I have checked the resistance of the heater circuit on the sensor which is not quite right. I am going to bite the bullet and buy a new sensor.
- doncarlyon
20 Oct 2011 05:25 #24076
by doncarlyon
Replied by doncarlyon on topic Re: Faulty O2 sensor, which one?
Try this guy -
www.carpartsexpress.co.uk
- Fuzzoire
20 Oct 2011 06:14 #24079
by Fuzzoire
Thanks for the tip but I ordered from
www.sparkplugs.co.uk
15 mins before your post.
I was able to match the exact part number. Quite cheap too.
Time to create page: 0.262 seconds
