Faulty O2 sensor, which one?
  • Fuzzoire
18 Oct 2011 18:21 #23970 by Fuzzoire
Faulty O2 sensor, which one? was created by Fuzzoire
7 - 8 months ago my engine warning light came on. After a mild panic and a trip to my garage they told me the O2 sensor was at fault. After reseting the system I was told to try it for a few days to see if it came back on.
Months on it has now come back on. I can easily replace the sensor but which one???:unsure:
I have found a place to get DENSO replacements. The short wire manifold sensor for £55 and the long wire cat sensor for £66.
After replacing the faulty sensor will the engine light go off automatically or will I have to get the garage to reset it for me, or is a simple disconnect the battery?
(oh it's a M13a engine)
  • doncarlyon
18 Oct 2011 18:45 #23974 by doncarlyon
Replied by doncarlyon on topic Re: Faulty O2 sensor, which one?
do you know the fault code?
  • Fuzzoire
18 Oct 2011 18:54 #23975 by Fuzzoire
Replied by Fuzzoire on topic Re: Faulty O2 sensor, which one?
Unfortunately I don't have a code.
I don't have a diagnostic wotsit to plug in.
I am currently trying to fathom out if I can get the code using a wire shoved into a plug under the glove box.
  • Nobby22
18 Oct 2011 19:05 #23978 by Nobby22
Replied by Nobby22 on topic Re: Faulty O2 sensor, which one?
I had this problem on my Grand vitara. Had a mechanic freind do it. I think generaly the first one, along the exhaust, goes first. And if i recall you need to have a code reader to turn the light off. I could be wrong, the grand vitara was a bit more advanced than the humble Jimny.
Nobby
  • Fuzzoire
18 Oct 2011 19:14 #23981 by Fuzzoire
X-Eng Simon wrote:
Behind the glove box you'll find a six pin connector. The diagnostic computer plugs in to this. However, by shorting two of the pins (2 & 4 IIRC) it will flash the engine warning light to indicate what fault codes it sees. Disconnect battery for a minute to reset the codes once you've fixed the problem.
There is lots of info on line about the connector and codes.
This helped me diagnose a faulty cam pos sensor.
Si
Just found this. Will give it a go tomorrow.
  • vitara_mad
18 Oct 2011 20:35 - 18 Oct 2011 20:36 #23990 by vitara_mad
Replied by vitara_mad on topic Re: Faulty O2 sensor, which one?
www.rhinopower.org/diag/cel.html
never had to disconect battery before once the fault is sorted light should go out
Last edit: 18 Oct 2011 20:36 by vitara_mad.
Time to create page: 0.215 seconds
