leaking help?
  • shootinginger@yahoo.co.uk
18 Oct 2011 17:00 #23954 by shootinginger@yahoo.co.uk
Replied by shootinginger@yahoo.co.uk on topic Re: leaking help?
ok thanks :) ill be changing that seal aswell, will it still be ok to use the car with it like that until i get the parts?
  • p1ngu32
18 Oct 2011 17:13 #23955 by p1ngu32
Replied by p1ngu32 on topic Re: leaking help?
Yes you should be fine to run it like that for a little while, nothing should fall off :)
  • adamatdraycott
18 Oct 2011 17:23 - 18 Oct 2011 17:23 #23958 by adamatdraycott
Replied by adamatdraycott on topic Re: leaking help?
I have recently done mine
Ran it for over a month... but it wasn't leaking as bad as your picture. The steering got progressively worse.
No need to spend any more than £10 a bearing. I used Timken bearings that were £8.
I replaced the pins too, but the old ones are fine and available for anyone who has damaged ones.
It takes a while to do the job... a couple of hours a side at a steady pace.
I did both sides, and would recommend to others to do the same
Last edit: 18 Oct 2011 17:23 by adamatdraycott.
19 Oct 2011 15:24 #24038 by shootinginger@yahoo.co.uk
my mechanic mates thinks its just the swivel seal thats gone and that i just need to take it apart and put the new seal in and thats it? :S
  • p1ngu32
19 Oct 2011 16:19 #24041 by p1ngu32
there is no oil in behind there like a landrover has, so if its leaking oil then it has to be comming from the seal inside on the halfshaft between the diff and the hub it usually only leaks if the king pin bearings are on their way out, hope this makes sense.
19 Oct 2011 16:47 #24046 by facade
Replied by facade on topic Re: leaking help?
Just believe us.
The kingpin bearings are always gone.
They come in two states:
Not fitted yet
Rusty as old iron and gone.
Time to create page: 0.159 seconds
