iPod Connection to Standard Radio, is it possible?
  • teafortwo0789
17 Oct 2011 11:26 #23838 by teafortwo0789
iPod Connection to Standard Clarion Jimny CD/Radio, is it possible? If so I'd welcome advice.
If not, guess I'll have to shell out on a new radio:(
Thank you in advance:)
  • VAXXi
17 Oct 2011 12:17 #23839 by VAXXi
You need an iPod-CeNet cable, something like this . Then you should get an AUX source available and you can fumble around with the standard controls like this . However, it's quite limited in functions (only 6 playlists, etc).
  • teafortwo0789
17 Oct 2011 16:25 #23870 by teafortwo0789
Replied by teafortwo0789 on topic Re: iPod Connection to Standard Radio, is it possible?
Many thanks for a superb response. Unfortunately my car is a 2003, so I think it may be too early a model. There is no aux port, that I can see, but I could be wrong.
  • myers647
17 Oct 2011 16:30 #23871 by myers647
hi you could just get a radio tuner connection. there not expensive at all.
thanks
james
  • myers647
17 Oct 2011 16:37 #23874 by myers647
EBAY ITEM NUMBER : 200581939156 IF THIS IS ANY GOOD MATE
  • VAXXi
17 Oct 2011 16:41 #23876 by VAXXi
AFAIK, they introduced the CeNet in 2001 so you should be covered. There is no physical aux port, just "software": you will select the AUX source when you want to play music from the iPod. Actually, the iPod will appear to your Clarion as a CD changer unit, that's why you get the 6 playlist limitation (because it emulated a 6-disc CD changer).
Considering the cable is quite expensive and you have a 2003 model (pre-face lift, so no rounded plastic corners) you can fit just about any 1-DIN (and use the remaining space for a CB radio perhaps) or 2-DIN unit (chinese all-in-one units with GPS and all whistles & bells).
Time to create page: 0.390 seconds
