outriggers for rock sliders
  • renard38
19 Oct 2011 16:24 #24042 by renard38
Replied by renard38 on topic Re: outriggers for rock sliders
yessss, god job ;)
thanks for the pictures
20 Oct 2011 20:27 #24150 by Johnniehec
Here's how I did mine using scaffold pipe and inch and a half by not quite sure but thick angle (recycled telephone exchange equipment frame).
Six inch length angle welded to front (behind front wheel) outrigger with two nuts welded to inside. then another length bolted to it long enough to stick out far enough for bar.
Rear bolted to rear outrigger (round one) captive nuts inside pipe, again long enough to stick out far enough.
Then stiched the scafold tube to the two protruding angles.
Unbolt, weld up, paint and refit.
Then cover with a liberal coat of mud to complete the effect!!
The angle iron brackets are fitted in the "V" position for maximum clearance and minimum "catchability".
21 Oct 2011 07:16 #24158 by Halford
good one Adam,
nice pics, look forward to seeing them fitted B)
  • tonybjimny
21 Oct 2011 16:16 #24183 by tonybjimny
Replied by tonybjimny on topic Re: outriggers for rock sliders
Thanks for all the replys.
Hi adam I noticed on one of your sliders you have welded a "u" shaped hoop
any reason for this?
Thanks again .Tony
  • Adamski
21 Oct 2011 16:51 - 21 Oct 2011 16:52 #24187 by Adamski
Replied by Adamski on topic Re: outriggers for rock sliders
tonybjimny wrote: Thanks for all the replys.
Thanks again .Tony
Its so that I can lock my car key under the car when I go surfing/camping/skinny dipping :whistle: etc.... using one of these :cheer: :
Last edit: 21 Oct 2011 16:52 by Adamski.
  • g187eev
23 Oct 2011 09:08 #24243 by g187eev
Replied by g187eev on topic Re: outriggers for rock sliders
We are currently drawing up some sweet weld on rock sliders for the Jimny, which will be available online in the next few weeks.
As people have already said, there is not an easy/nice way of bolting on a good sturdy rock slider as the chassis/sill are very awkward shapes to work with.
RB
Time to create page: 0.341 seconds
