outriggers for rock sliders
  • tonybjimny
16 Oct 2011 18:42 #23796 by tonybjimny
outriggers for rock sliders was created by tonybjimny
Hi can any one help with photos or plans/ diagrams for fabrication off outriggers and rock sliders to fit a 2000 jimny. (ps I would intend fitting an external cage to them at a later date.
any help gratefully recieved.
Tony.B
17 Oct 2011 20:56 - 17 Oct 2011 20:57 #23898 by kirkynut
Here is a picture of my Rocksliders. The tubes going under the car are welded to spreader plates which are then welded direct to the side of the chassis. No pictures of the welds and spreader plates taken I'm afraid but I'm sure you can imagine.
www.bigjimny.com/index.php?option=com_ph...ory&id=43:&Itemid=55
I now have a cage mounted to them as seen in the pictures of mine in the gallery. The Rocklsliders have been used on Rocks too - the car has been dropped hard down onto rocks on the sliders causing no damage and has now been on it's side and the cage flexed a little but stopped major damage and went back to where it ought to be when it was righted.
I wouldn't have sills now if I had no sliders!
Hope this helps.
Last edit: 17 Oct 2011 20:57 by kirkynut.
The following user(s) said Thank You: tonybjimny
  • Adamski
18 Oct 2011 09:54 #23923 by Adamski
Replied by Adamski on topic Re: outriggers for rock sliders
I'm going to start making mine in about half an hour, I'll take some photos and will get them on here.
Like kirkynut, I too am using spreader plates to weld to the chassis.
  • jimny5
18 Oct 2011 15:45 #23939 by jimny5
Replied by jimny5 on topic Re: outriggers for rock sliders
I used tube and hammered it into chassis about a foot, where holes are then welded around them. And there are solid.
  • trextr7monkey
18 Oct 2011 17:16 #23956 by trextr7monkey
Replied by trextr7monkey on topic Re: outriggers for rock sliders
I bought some chrome side bars (tubes ) locally that were very cheap, decided not to fit them but sold on to a bloke a long way away so made up some brackets that he could bolt onto chassis- basically an out rigger fastened to some very heavy angle reinforced with a gussett that would bolt through chassis, he said they fitted fine :D but welding to chassis would be best option, for sure
atb
Mike
  • Adamski
19 Oct 2011 14:09 #24028 by Adamski
Adamski wrote: I'm going to start making mine in about half an hour, I'll take some photos and will get them on here.
As promised:
Mock up made of the rock sliders out of wood:
Marking the metal the same size as the mock up:
Cutting the metal to length:
Welding it all together:
Grinding angles in the ends of the 2x1 so that they fit flush on the chassis rails:
Done!.... Now I just need to paint them then get them welded on to the chassis:
I'll post pictures when completed and fitted to the car however it won't be for a few weeks.
Time to create page: 0.162 seconds
