02 4x4 problem +recon transfer box
- Waite
20 Oct 2011 16:16 #24117
by Waite
Replied by Waite on topic Re: 02 4x4 problem +recon transfer box
yes i agree. Is it something i could do. ? many thanks
20 Oct 2011 20:48 #24151
by facade
Replied by facade on topic Re: 02 4x4 problem +recon transfer box
If you have the room, and a toolkit, yes you can do it.
Rear
drain oil
remove propshaft
remove wheels and brake drums
undo brake pipes at wheel cylinders, (or undo all the pipe retaining clips and let the pipes straighten out: very naughty, but it worked for me)
undo 4 nuts behind brake backplates, snatch halfshafts out with slide hammer
undo nuts around diff
pull diff out
Front
drain oil
remove propshaft
remove wheels and brake callipers, tie up out of way.
undo all bolts around swivel seal and release seal
part all steering knuckles
remove kingpins
pull hub assemblies off with halfshafts still in
remove diff
change swivel bearings for new ones when refitting
Rear
drain oil
remove propshaft
pull diff out
Front
drain oil
remove propshaft
remove kingpins
remove diff
The following user(s) said Thank You: Waite
- Waite
21 Oct 2011 19:36 #24197
by Waite
my god.my mechanic.seems its rear diff i will keep you posted.
- Waite
21 Oct 2011 19:38 #24198
by Waite
(my god.my mechanic) .seems its rear diff i will keep you posted.
- Waite
15 Nov 2011 16:56 #25835
by Waite
:laugh:
:lol: :woohoo: :pinch: ed phoned 4x4 all working.turn out it was font diff.it looks like someone had tried to repair it.many thanks to all who gave imput.
