02 4x4 problem +recon transfer box
  • Az1987
18 Oct 2011 19:21 #23983 by Az1987
Replied by Az1987 on topic Re: 02 4x4 problem +recon transfer box
Depends what you want to do with it I would say try and put it back to standard as it will tie up with the ratios in the transfer and gear box
  • Waite
19 Oct 2011 15:59 #24040 by Waite
Replied by Waite on topic Re: 02 4x4 problem +recon transfer box
Not sure found problem as two garages have said the bolts holding axle do not look like they have been touched. which made them doutfull.
19 Oct 2011 16:51 - 19 Oct 2011 16:53 #24047 by facade
Just ask them to check the differentials have the same ratio front and rear. From your earlier reply, they haven't.
Jimnys use special "rustomatic" bolts between the axle and the suspension arms. They look rusty and undisturbed after a few weeks. Mine look 100 years old and they were cleaned up perfectly last year when I changed the trailing arm bushes.
The differential could have been changed with the axle still in place, this is easier than changing the axle, but they don't break very often, so there isn't really any reason to change one.
Last edit: 19 Oct 2011 16:53 by facade.
  • Waite
19 Oct 2011 19:10 #24063 by Waite
Ok thanks I will keep you posted cheers
  • Waite
20 Oct 2011 13:23 #24099 by Waite
Hi told mechanic about checking diffs. he seem to think he will have to take them out. and won't be an
easy job.?
20 Oct 2011 15:11 #24110 by facade
He wants to count the teeth on the crownwheel.
Removing the diffs is a bit of a pain, and takes a morning.
It is difficult for us to diagnose problems by forum, rather than having the car next to us.
Based on what you said, I think the diffs are different. If it were mine, I'd take them out, count the teeth, and get one to give a matched pair, then refit.
This would leave the car on axle stands immobile for a while though.
Time to create page: 0.182 seconds
