Noisy internally !!
  • Gromit
09 Oct 2011 17:09 #23349 by Gromit
Noisy internally !! was created by Gromit
Some advice please.
My new Jimny project came with a 2" bodylift but I"ve noticed a lot of engine noise coming up from the gear/transfer levers and it seems as though the gaiters now dont seal the gap properly. Is this normal after a body lift or is there some way of sealing it up a bit better.
  • srcars
09 Oct 2011 17:22 #23352 by srcars
Replied by srcars on topic Re: Noisy internally !!
:unsure: Dont think even if the rubber gaiters wernt fitted properly they would prevent excesive noise coming through. What sort of noise do you have, exhaust, drive-train ?
  • Gromit
09 Oct 2011 17:29 #23355 by Gromit
Replied by Gromit on topic Re: Noisy internally !!
Just general engine and road noise definately coming up at the levers.
  • srcars
09 Oct 2011 17:40 #23357 by srcars
I can tell you having just re-asembled mine. That under the cosmetic gear stick gaiter (the one you see that fits on the plastic gearbox tunnel) you should have another rubber gaiter on the gearstick which attaches to the flat rubber held down by 4 bolts which creates a water proof seal. If I remember correctly the transfer box lever just has the 1 gaiter that bolts to the floor.
  • Gromit
09 Oct 2011 17:47 #23359 by Gromit
Aah, both gaiters are just loose, not fastened down in any way !!
  • zuki andy
09 Oct 2011 17:48 #23360 by zuki andy
Replied by zuki andy on topic Re: Noisy internally !!
I to have just fitted an ORA 2" body lift. and yes lots more road noise from the gear lever gaiter, it now does'nt fit as good and occasionally comes off, get loads of road noise then as you put it back on gets a little quieter.
