215/80R15 tyres
- tups93
17 Feb 2010 07:35 #2321
by tups93
215/80R15 tyres was created by tups93
hey all,
looking for some help,
looking at getting some mud tyres soon hopfully,
and have been debating 195/80R15 or 215/80R15,
i like the 215s due to the every so slightly more ground clearance,
as my jimny is my daily driver and has a 2.5" lift on it fuel consumption does concerne me some what,
will the 215s make it worse or just the same with the 195s?
pros and cons please guys?
cheers
cheers
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
17 Feb 2010 09:16 #2323
by funkyjimny
Replied by funkyjimny on topic Re:215/80R15 tyres
215/15's will be worse and the arches will need trimming, just the front and rear of the front wheelarches.
Thanks
Gary
Thanks
Gary
- ooky_123
17 Feb 2010 10:29 #2324
by ooky_123
Replied by ooky_123 on topic Re:215/80R15 tyres
Actually 215's will fit no problem. you will have to trim about 2" off the rear arches at the bottom, but other than that you'll be fine.
I have found that you will get an extra 2" or so of clearance, but top speed will be affected, and you may have to use the Low box more often offroad as you loose a little control when trying to go slow.
Also, overall gearing will be screwed too as you ll be doing about 20% faster than teh speedo is reading.
You can drive with the taller tyres, but you will have difficulty keeping in 5th when the revs drop .. so fuel economy will be impacted quite noticeably
- funkyjimny
- Moderator
17 Feb 2010 11:19 #2330
by funkyjimny
Strange how different cars need different bits trimming ! I'm pretty sure you'll need to trim the arches somewhere with the 215's, whereas you should get away with it on the 195's. Gearing will be better on the 195's.
I think 215's are the start of the slippery slope towards a rocklobster box and some big tyres!
Gary
Gary
- ooky_123
17 Feb 2010 12:36 - 17 Feb 2010 12:39 #2333
by ooky_123
This is indeed very true ... We now have the "Bug" for 31's but that means an investment of £1000 for a new TC Box.
Here are a few PIx of our 215rx15's .. you can see the rear wheel arch that has been doctored in the second picture..
The Jimny currently has KAP +2" springs .. with Martins "extra" 1" shock relocation brackets on the rear
Last edit: 17 Feb 2010 12:39 by ooky_123.
- tups93
17 Feb 2010 14:50 #2334
by tups93
Replied by tups93 on topic Re:215/80R15 tyres
think ill just stick to my 2.5" lift and 195s,
i just wanted to double check before totally writting off the 215s but if im fuels going to get a hard beating then 195s are the way forward for me.
cheers for the replys guys very helpful.
Time to create page: 0.258 seconds
