Unpredictable handling
  • judder
05 Oct 2011 08:33 #23098 by judder
Unpredictable handling was created by judder
Hi Guys, ever since i fitted an adjustable panhard rod, the handling has been a bit dodgy. More noticably at speed going over rough road surfaces the back end seems to skip and want to drift out. At first I thought I needed new shock absorbers, but the car sailed through an mot. I assumed I had fitted the bar correctly as I used the old one as a reference. The car has not been lifted. So the question is - how do I know for sure it's not the cause ?
Stephen
  • viciouspenguin
05 Oct 2011 09:50 #23102 by viciouspenguin
Replied by viciouspenguin on topic Re: Unpredictable handling
Hello,
considering that has been the only thing changed it does seem to point to the panhard, i expect you havent quite got the measurments right. i should pick two reference points on the axle and chassis and check they are both the same.
incidently why add an adjustable panhard if you have no lift?
  • Adamski
05 Oct 2011 10:29 #23104 by Adamski
Replied by Adamski on topic Re: Unpredictable handling
Check the panhard rod bushes for play. I had brand new adjustable panhard rods and bushes however the metal collars in the bushes were too long (manufacture defect apparently) which meant that there was a lot of play and the car was undriveable. I cut about 7mm of each collar, refitted the panhard rods and the car has driven perfectly ever since.
  • judder
05 Oct 2011 12:26 #23107 by judder
Replied by judder on topic Re: Unpredictable handling
Thanks for the quick replies. I fitted the adjustable one as the standard one on mine had broken on my first off road day. I read through the forums and found it was a common weakness. Also I am considering lifting it in the future.
A quick measurement found it's about 2-3mm difference. Don't know if this would make a great difference ?.
I've let the tyre pressures down a bit as they might have been a bit high/hard - was 31F 30R Now 29F 27R Though it's running Bridgstone 205/70/15 All Terrains
Not sure about the inserts - can remember when ordering them, Kap were aware of a pre existing problem and they were supposed to have sorted that out.
05 Oct 2011 13:19 #23112 by Halford
Replied by Halford on topic Re: Unpredictable handling
Hi Stephen
welcome to bigjimny
THINK YOU'RE STILL RUNNING AT TOO HIGH A PRESSURE and FRONT tyres should be lower pressure than REARS
205/70/15 duelers should be set at 23psi front / 26 psi rear
my grabber AT2's 205/75/15 are at 24/27 on the road - perfect setting
  • judder
05 Oct 2011 13:42 #23115 by judder
Thanks for the welcome - I really need to get a pic up on my profile - been lurking around for a while - just never posted. Looks like it's the tyre pressures indeed - took it out there and it's improved - I'll try your suggested 24 at the front and try again, but it's looking good so far. Can't believe it would make such a huge difference.
Time to create page: 0.319 seconds
