O.R.A transfer box
  • vitara_mad
  • Visitor
  • Visitor
05 Oct 2011 08:12 - 05 Oct 2011 08:16 #23096 by vitara_mad
Replied by vitara_mad on topic Re: O.R.A transfer box
does your box have the 2wd low mod done to it as that might explain why yours is not the same pattern
your 6.1 transfer box is no differant to a sj transfer box apart from the gear ratio inside so it should have the same shift pattern unless its had some other mod done to it
Last edit: 05 Oct 2011 08:16 by vitara_mad. Reason: spelling as usual lol
  • vitara_mad
  • Visitor
  • Visitor
05 Oct 2011 08:15 #23097 by vitara_mad
have a look at some of these shift patterns
suzukiclubuk.co.uk/viewdiy.php?ID=12
05 Oct 2011 09:01 #23099 by mlines
Replied by mlines on topic Re: O.R.A transfer box
My guess is that as the gears in a 6:1 transfer box are newly cut gears, the gear faces are not bedded into each other, therefore there will be quite a lot of gear noise from it which should reduce as the faces wear into each other.
I know with a 4:1 conversion which re-uses gears which have different wear patterns on them from the previous use, then the noise is loud.
  • Seawolfvarna
  • Visitor
  • Visitor
05 Oct 2011 09:37 #23101 by Seawolfvarna
Replied by Seawolfvarna on topic Re: O.R.A transfer box
After 2 hours of more bending of t-box lever, I confirm, that finally we match exactly the pattern, showed above. Now there is all clear and working properly. About the noise, I hope that Martin is right and in time will be everything ok.
Thank you, for all answers!
06 Oct 2011 13:49 #23159 by kirkynut
Replied by kirkynut on topic Re: O.R.A transfer box
I used to have an SJ410 and the transfer box on that whined but there was nothing wrong with it.
I now have a Rockwatt 4:1 Rocklobster and it whines relatively loudly and always has done. It has gone through a few changes of note, but remains at the same volume!
Also, when you look at the mounting system, a bolt goes through the outrigger and then through a hole in the bracket/bucket mount on the transfer box.
That bolt must touch the side of the hole in the outrigger and the side of the hole in the transfer box bracket/bucket and will transmit the noise through the bolt. I have said this before and a manufacturer of them argued that this is not the case and that the nylon bushes used in this type of installation soak up the noise. I'm sure they do their job well but the bolt still joins the two together and must touch both bits of metal and will still transmit the noise.
Once when greenlaning in Derbyshire / The Lakes - I forget where we were - before I had my Rocklobster I bashed the old guard I had on my transfer box and it touched the transfer box, causing the same noise I have now, but a little louder. A quick straightening exercise with a BFH sorted it and the noise went.
This is why car manufacturers use bonded mounts where studding is bonded into the mount welded to plates seperated by rubber. Then the rubber stops the studding touching and transmitting the noise.
I hope this helps re-assure you that it's nothing to worry about.
If I did enough miles I'm sure mine would bed in but I only do a few thousand a year.
The following user(s) said Thank You: Seawolfvarna
  • bluejimny
  • Visitor
  • Visitor
06 Oct 2011 14:47 #23163 by bluejimny
Replied by bluejimny on topic Re: O.R.A transfer box
well when i built up my rocklobster (after the original one was built wrong) i found it quite quiet but i have standard oe suzuki bonded bushes installed, and touch wood never had any problems with them
Time to create page: 0.168 seconds
