Click, Slap or Tapping noise front hub ????
- teafortwo0789
- Visitor
29 Sep 2011 14:38 #22780
by teafortwo0789
A big thank you to the BJ fraternity. The noise was very simple to resolve. I took the wheel off, (ali Toblerone) to check the brake calliper to see if it was loose.
1.The wheel nuts weren't really loose, but not rock solid!
2. Tightened the calliper, seemed very solid, so probably a waste of time.
3. Replaced the wheel using a breaker bar to tighten.
Clicking gone yippee :lol: :lol:
Problem now, is it will now be impossible to remove the wheels with a standard Suzuki wheel brace!!!
The moral - always check after garage changes tyres.
Again thank you all, Tony.
Replied by teafortwo0789 on topic Re: Click, Slap or Tapping noise front hub ????
29 Sep 2011 15:09 #22781
by facade
Use a torque wrench to tighten them. Or you will be proved right
Always check anything you didn't do yourself: so you might as well do it yourself in the first place
Replied by facade on topic Re: Click, Slap or Tapping noise front hub ????
Time to create page: 0.284 seconds
