Click, Slap or Tapping noise front hub ????
  • teafortwo0789
  • Visitor
  • Visitor
28 Sep 2011 17:27 #22731 by teafortwo0789
Click, Slap or Tapping noise front hub ???? was created by teafortwo0789
B) 2003 Jimny, Vacuum hubs, which gives off a noise as a Click, Slap or Tapping noise from the front off-side wheel in time with the rotational speed of the wheel.
Initial thoughts:-
- Having driven over a newly tarmac road I thought I'd picked up a sticky stone in the wheel tread, but the tyre is clear.
- AlsoI suspected a nail, but there where none.
- Suspected clicking CV joint, however having jacked up the car and rotated the wheel, no clicking only a slight backlash in the gears. Put in 4wd also no noise.
Another test drive and when driven slowly (15mph - 20 mph) clicking loudly, slight pressure on brakes with minimal retardation clicking vanishes and on releasing the brake, clicking instantly returns.
- Brakes smooth and progressive no pulling to one side.
- Just passed MOT 6 days ago. 37,000 miles on clock.
- No off roading yet.
- Toblerone wheels.
- No death wobble or shimmy.
HELP .............................. suggestions
  • goatboy
  • Visitor
  • Visitor
28 Sep 2011 17:43 #22733 by goatboy
Cv joints may only make a noise when under proper torsional (spelling?) force, I.e when being driven by the engine.
is there any sign of split Cv boots or anything? Clicking any different when turning at full lock?
28 Sep 2011 17:49 #22735 by facade
Mine made a loud click from the offside rear. Definitely the rear, even the passenger reckoned the rear.
Couldn't find anything at all. Louder when turning right, must be wheel bearing.
Spent 10 minutes driving in small circles round the passenger on a car park, won't make the noise.
Had the rear jacked up, took wheel off, nothing.
Gave up and was going inside when I spotted the nail sticking out of the front tyre :whistle:
  • teafortwo0789
  • Visitor
  • Visitor
28 Sep 2011 18:02 #22740 by teafortwo0789
Replied by teafortwo0789 on topic Re: Click, Slap or Tapping noise front hub ????
I also thought of the torque element.
- When driven and brakes applied, I kept the engine pulling so I was driving against the brakes.
- Tried in 4wd and the same result, brakes stopped clicking and started again on release.
- No splits on the seals and no leaks to be seen.
- I also raised the rear wheels and there was no noise on rear wheels. No nails etc.
I'm off on holiday tomorrow and I will strip down on return. I will also feed back result to BJ.
Thanks to you all, keep them coming!!
  • martysmith
  • Visitor
  • Visitor
28 Sep 2011 19:34 #22742 by martysmith
Replied by martysmith on topic Re: Click, Slap or Tapping noise front hub ????
come across this every week in my job as a mechanic and its normally a loose brake caliper or shims missing off pads hope this helps
  • teafortwo0789
  • Visitor
  • Visitor
29 Sep 2011 12:56 #22774 by teafortwo0789
Hi, Thank you. I'll check it out ASAP on my return.
